I recently downloaded Cuttermaran and have figured out how to cut ranges of video, and I want to use that cut video to make a DVD. How do I do that using DVDShrink? Do I need to convert the Cuttermaran project file to something else? Thanks.
Results 1 to 9 of 9
You can't make a DVD with DVD Shrink. It isn't an authoring program. Try TDA to start simple, GUI for DVD Author, DVD Lab Pro or DVD Workshop 2 to get more complex.
Read my blog here.
I'm only trying to use DVDshrink as the burning program, because I'm familiar with it. How can I burn the "Cuttermaran project file" I've finished working on?
What has cuttermaran actually output ? Unless it is a DVD compliant structure you can only burn it as a data disk for PC use. CDBurnerXP Pro can do this for you.
If it is mpeg or mpv files then you need to author them (see my previous post).
If it is compliant, you can just open it in shrink as you would any ripped disk.Read my blog here.
When I click "Properties" on the file, all it says is "Cuttermaran Project File." Under "Opens With," it says "Cuttermaran - GUI."
I suspect that all the project file is a list of edits you marked out. You need to output your edits to some format. I haven't used cuttermaran, so I don't know if it outputs mpeg or VOB. If it is mpeg, author and burn. If it is VOB you will probably still have to create IFO files for it before burning.
Read my blog here.
I was looking at the freeware DVD author programs...people seem to like DVDAuthorgui. But I had some questions about it. What is GUI? And are you able to actually see the video as you work on it? The screenshot doesn't show that feature. Thanks
Can I edit HiDef files in same project as StandardDef files?
By cspaul1234 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2011, 19:39 -
Studio14 HD Ultimate, can't open project files from ext. HDD!!!
By rivrbyte in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 14:49 -
Project HD Image files without jaggies
By tram in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2009, 12:37 -
Updating files inside a project
By paulom in forum VCDEasy GeneralReplies: 1Last Post: 23rd Sep 2008, 14:00 -
Cuttermaran with Vista?
By Rychezilla in forum EditingReplies: 7Last Post: 18th Apr 2008, 17:16
