ok
in virtualdubmod i open my video source which happens to be a .vob file and i go to streams the stream list then i right click the audio (Starts in AC3 format) then choose full processing then right click again and choose compression but i dont see lame in there.... so where and how do i install lame so i can choose it in virtualdubmod?
I don't think you will get lame to work with VD, at least not without a lot of effort. There are workarounds, if you do a search for 'using lame with virtualDub' you might find some. It doesn't sound like it's worth the effort.
Another solution you could try, is to save the ac3 track as a WAV, then use Audacity to encode it to MP3, cause Audacity uses LAME for its MP3 encoding. Then add the MP3 track into the list in Virtualdubmod.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Personally I don't think it's that hard - I'm pretty sure I just installed it from here http://rarewares.poskolio.com/lame3.96.1.zip and it works fine in virtualdubOriginally Posted by redwudz
If in doubt, Google it.
help with virtualdubmod
By losernoob in forum SubtitleReplies: 7Last Post: 12th Sep 2011, 11:23 -
What should I use instead of VirtualDubMod?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 03:06 -
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 06:28 -
Virtualdubmod
By Irolaan in forum Newbie / General discussionsReplies: 0Last Post: 19th Sep 2009, 13:57 -
About VirtualDuBMod
By YairGOW in forum Video ConversionReplies: 4Last Post: 10th Sep 2009, 17:45
