  1. Member Nitemare's Avatar
    Jan 2003
    More and more DVDs I watch show a logo/splash screen when I hit the stop button on the remote. A good example of this would be Batman Begins. When I hit STOP on the remote a Batman logo appears on the screen instead of my DVD player's default screen.
    Is there any way to do this with my home-made DVDs? I searched but came up empty.
    Thanks!
    Nitemare
    Even a broken clock is right twice a day.
  2. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    You can do a search around here for "Jacket Picture". Sony DVD Architect can do it. And you can also easily do it, following this guide:
    How to make a Jacket picture for DVD
    Jacket cover images (generally referred to as Jacket_P images) are used by some DVD players to give a visual indication of what disc is available. Jacket_P images are most often utilized by players that can hold more than one DVD at a time (such as a Sony DVD jukebox).
    Adding Jacket_P info to a disc is pretty simple. You will need to create one image that will be scaled to three different sizes (or, you could create a separate image for each size if you want to provide simplified graphics at lower resolutions). The three sizes are made available so that the DVD player can select the appropriate one for its display context (menus, details, etc.)
    The sizes and required file names are as follows:
    J00___5L.MP2 720x480 ntsc
    J00___5M.MP2 176x112 ntsc
    J00___5S.MP2 96x64 ntsc
    J00___6L.MP2 720x576 pal
    J00___6M.MP2 176x144 pal
    J00___6S.MP2 96x80 pal
    Note that your menu aspect ratio should be 4:3 and that there are three underscores in a row in the filenames.
    As indicated by the filenames above, the images should be saved as MPEG2 encoded images.
    Once you've made the files, create a Jacket_P folder, store the images in it, and include the folder on your dvd disk along with AUDIO_TS and VIDEO_TS
  3. Member Nitemare's Avatar
    Jan 2003
    I'll try that. Thank you for the answer.
  4. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Any time
    Apr 2003
    my computer, where else?
    good, short guide info. may come in handy in the future. thanks, Cunhambebe
    I said I'll be done in a minute. I meant a Microsoft minute.
  6. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Don't mention it you're welcome. Thanks to BJ_M or BM_J .... I haven't seen him around here for a while....
