Used the latest version of DVD Fab Decrypter and am using DVD Shrink to compress. While Shrink is encoding around the 74% mark, the buffer gets up to around 1.5GB and Shrink dies. It also says "Not enough storage is available to process this command".
I had my friend run it as well on his machine and he wound up getting the same error.
What gives? We both tried the whole disk but it won't go through. If we select "Main Movie" only, then there's no problem - it goes through the whole process and I can then burn it.
Which version of DVD Fab Decrypter ? The current version corrects issues that caused shrink to crash using DVD Fab decrypter output.
Read my blog here.
I was using the latest version of DvdFab Decrypter (2.9.5.8) and had the same problem with DvdShrink (3.2.0.15) as maldb. I tried with and without running it through VobBlanker and it didn't matter.
I had read on another board that people were using CloneDvd with success, so I tried it. It worked not only by allowing CloneDvd to transcode without errors, but also if I just ran it through with no compression, and then put the results into DvdShrink for trancoding. -
You've stated:
How much hard drive space and virtual memory do you have?
dvd shrink error out of memory???
By carlos28355 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2014, 00:04 -
DVD Shrink error - Out of Memory
By xoADAMox in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2011, 10:32 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
DVD Shrink-short of memory
By Mållgan in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 07:02 -
DVD Shrink not releasing memory when done?
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2007, 11:12
