I have been attempting to generate a VCD/SVCD
(have tried both) of video captured to AVI from an
analog source. I have been capturing in VirtualDUB
using the PICVideo MJPEG codec set at the highest
quality.
The AVI's turn out fine but when I use TMPGEnc to
do the MPEG encoding anything in motion in the resulting
file gets grainy or "blocky" (not sure what the proper
term would be). The faster the motion, the worse the picture.
I've tried capturing at the standard resolutions for
VCD/SVCD as well as capturing at higher resolutions and
resizing during encoding; playing with the Motion Search Precision settings; and playing with the bitrates. Does
anyone have any suggestions?
The best luck I've had so far has been to make XVCD's using the following settings in TMPGenc: MPEG-1 352x240, 29.97fps, CBR-2375kbps, 224kbps audio, Motion Search-Highest Quality, Use Floating Point DCT, Uncheck the box that says No Motion Search for still picture, Soften Block Noise (35 & 35), and use the Toolame external audio encoder.
Of course the bit-rates you choose will depend upon how many CD's you plan to use. But keep in mind that if your bit-rate is too low, it will not look good, and if it is too high, your DVD player might not be able to handle it.
I have also experimented with SVCD's and found that still scenes look nice, but any motion scenes just look like crap. So I'm sticking with XVCD.
Encore CS5 keeps re-encoding my motion menu - help!
By Killer3737 in forum Authoring (Blu-ray)Replies: 1Last Post: 31st Jan 2012, 13:52 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 11:40 -
Why Mpeg video flickers on camera motion?
By Vishal0011 in forum Video ConversionReplies: 2Last Post: 4th May 2010, 19:23 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 18:02 -
How do I convert Motion JPEG to MPEG-1?
By TheEvilHammer in forum Video ConversionReplies: 6Last Post: 18th Oct 2007, 19:58
