Hello, I have a Sony CD-RW650HS disc. If I make an SVCD out the disc, can I erase the show after I am done watching it and get back the space it used up on the disc? Thanks.
Yes.
He's a liar and a murderer, and I say that with all due respect. -
Just to expand a bit. CD-RW are pretty durable media I have owned at least 150 at one time.
I wouldn't recommend them for long term storage but the way you want to use the disc is perfectly fine. Some say that they will last for thousands of reuses but at the very least it should hold up to hundreds of uses.
In most cases use the quick erase. I recall a couple of discs that I reused and gave some errors so I used a full erase and it solved the problem.
Enjoy
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
Sony DVP S360 DVD player - No DISC problem
By weenie02000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Aug 2009, 09:43 -
burn video from sony hdr-1 to blu ray disc
By pistol pete in forum Newbie / General discussionsReplies: 0Last Post: 2nd Mar 2008, 22:45 -
Sony´s DCRDVD403 won´t access its own disc
By wvpneto in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2007, 21:48 -
Sony DVD recorder ruined my mini disc
By levl in forum DVD & Blu-ray RecordersReplies: 53Last Post: 10th May 2007, 14:27
