I am thinking of using HDMI when I receive my Samsung 46" DLP and an Onkyo S-780. I have a question though. I know that HDMI=video and audio+best quality. However, I don't think my receiver will have HDMI so how am I supposed to hook it up to the receiver? Is there an optical out on the TV or something? I am very confused. to clear it up:
Do I have to have a receiver that has an HDMI input if I want to use that for the TV but want digital audio hooked up to the receiver as well?
What are you using for a TV tuner? If a HDTV cable box (most common), you will have analog component, DVI and/or HDMI video out plus an optical and/or coax SPDIF for digital audio out. Any of the video cables can be used to the HDTV. SPDIF audio goes to your receiver.Originally Posted by tjpark1111
This same basic hookup would be used if the tuner was DBS or an external over the air DTV tuner. If the tuner is built into the HDTV, it will have a SPDIF output that goes to the audio receiver.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
so there is no way of connecting optical to a home theater receiver? i probably wouldnt care anyways... My question was though, for a dyd player. Say the dvd player had an hdmi out, and i connected that to the tv. HDMI carries audio and video, but are you saying I can still stream audio to the receiver by coax? It automatically deactivates the audio signal that is carried over HDMI and onto the coax? Or are two streams going out at the same time? Also, I heard it is best for a receiver to process sound on a dvd player, so would setting it up this way make the receiver process the sound? thx. What I am basically trying to do is clear up confusion about connecting stuff on how to get the best picture/sound possible with my hardware.
That would be in the DVD player menus. Often audio defaults to the HDMI connector unless you select something else. Make sure before you buy the DVD player.Originally Posted by tjpark1111
HDMI video to TV.Originally Posted by tjpark1111
AC3 audio to the receiver.
If you also want audio to come from the TV and if your player won't let you feed both HDMI and optical, you may need to feed analog audio to the TV.Recommends: Kiva.org - Loans that change lives.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
HDMI Wall Plate>>Quality?----HDMI over Cat5E/Cat6????
By cpeters12 in forum DVB / IPTVReplies: 5Last Post: 28th Jan 2011, 03:27 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40
