I have dozens of MOV (QuickTime movies) file which I would like to convert to AVI format.
File size is not matter but looking for best result (same as original). Can any one tell which codec I can use for excellent quality avi?
Thanks in advance
I like XviD over all others mainly because of the "Target Quantiser" feature. Just set a TQ of 2 or 3 and you can almost guarantee that you will retain pretty much all of the quality from your source. You don't have to know much or worry about bitrates, etc either.
If in doubt, Google it. -
Note sure about codec's you require , but the best program for rotten mov's conversion is called super , it dose a brilliant job and can convert to alot of differnt formats .
I only found it after many of the game previews (movies) I downloaded where in mov format , and searched about for a conversion app that worked , its freeware , no hidden catches , apart from the box that appears before the app itself gets up and going .
For those with those new mobiles that play video , its the tool to get .
As always , if you's cant find it through google search , ect , pm me for link to it .
.avi to .mov gives me a 0 kb size file
By kusuri in forum ffmpegX general discussionReplies: 3Last Post: 10th Oct 2012, 12:14 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
.srt Subtitle in "not DVD" File like mp4, mov or avi
By oldMac in forum ffmpegX general discussionReplies: 2Last Post: 8th Apr 2010, 18:12 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Best way to convert .mov(QT) file to an .avi file...... is?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 21:05
