Ok, I have four .avi files and I want to make them into one DVD movie to burn onto a DVD-R disc to play in my Home DVD Player.
The files are one movie which is split into four separate .avi files.
Whats the easiest and less time consuming way to get this job done?
Thanks in Advance.
The easiest / fastest way to do things is often the worst way to go about things. Does quality come into the equation anywhere or can it look like crap, so long as it's easy and fast ?
If you must go fast, add all 4 files to DivxToDVD, then import each title it creates into your favorite authoring software and add them to the same track.
If you want the very best you can get, use either http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm (or any of the other AVI to DVD guides that use dedicated encoders in the Guides section) and do each file manually, then let your authoring software do the joining.If in doubt, Google it.
So what's the best software for joining mpeg-2 files together?
By snafubaby in forum EditingReplies: 1Last Post: 23rd Aug 2009, 03:15 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 09:13 -
Joining mpeg-4 files
By GAR in forum EditingReplies: 8Last Post: 3rd May 2008, 22:42 -
Joining 2 mpeg files together
By efiste2 in forum EditingReplies: 3Last Post: 28th Jul 2007, 07:37 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
