Heres the scenario
I bought a dvd, turns out the main movie doesnt had malay subtitle i want (others included though, eng, chi etc)
Copied it using dvdecrypter. Cut,edit,join using videoredo.
there are 2 type of file,
1-main movie
Video: MPEG2 Video 720x480 (16:9) 29.97fps [Video]
Audio: Dolby AC3 48000Hz 6ch 448Kbps [AC3]
2-extra scene
Audio: Dolby AC3 48000Hz 6ch 192Kbps [AC3]
ive join both these type of file, so the movie play with extra scenes.
After joining, i use subtitle workshop for subtitling.
Before edit/join = FPS shows 29.97
After edit/join =FPS shows 101760794361856
Is this normal? is it ok after later on converting it to dvd?
You could have just loaded the two movies into something like DVD Lab Pro and set them to play in order, or add a simple (or complex) menu. You could also add the subtitles there.
Read my blog here.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Camtasia - video editing question
By Noek in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 15:32 -
Video Editing Software Question
By Souwalker in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2009, 21:08 -
Vista 64 and most Video editing software QUESTION
By zapper130 in forum Capturing and VCRReplies: 7Last Post: 20th Apr 2009, 19:04 -
Question About Video Only Editing
By greyhavens49420 in forum EditingReplies: 1Last Post: 1st Feb 2008, 01:18
