With all the compatibility problems the PV256 is having
with certain motherboards, is it better to get the PV356
instead since the PV356 connects to the PC via USB?
I think both cards use the same mpeg 1/2 encoding chip
which I think is the SteamMachine chip.
You may be correct Tony. However seeing the problems people are getting with the ASD Instant DVD which has the same chip I think I will wait until USB2 or Firewire versions come out or the second generation release.
I must admit the quality of capture with some of these new MPEG1/2 capture cards is very impressive. Check some of the posts in this group for links. The future looks good.
