  1. im tryin to convert an avi video to and mpg using TMPGenc. when i opened one of my vids, i ran the program like normal and all went well, but after awhile, the program wasn't responding. i tried again, and it froze at the same spot it had previously. i than tried another video only to find out that it does the same thing at another position. does anyone know what's goin on and knows how to solve this?
    Dec 2001
    Oregon
    I am having the same problem as you, so I am very interested in a fix too. Seems like video locks up, but audio keeps going and continues to write to the mpg file with the frozen video. You too?
    Only thing I found here:
    http://www.vcdhelp.com/oscomparisons.htm
    scroll down to:
    Results
    Win98SE 00:12:37 Locked Up
    I am using win98 SE, are you?
    <font size=-1>[ This Message was edited by: shplat on 2001-12-25 01:31:02 ]</font>
  3. i've got xp pro
  4. I have the exact same problem.
    I have tried to solve it every possible way I could think of; looking in the registry, re-installing the full (WInXP) system. Etc.. etc...
    Older already done MPG files do work but newly made mpg files suddenly won't cut/join anymore.
    In the end I suspect TMPGenc 2.02 to be the guilty one, IMHO it writes something wrong in the registry or changes the codec or whatever.
    So I tried all older versions of TMPGenc, and none worked till I found the earliest version 1.2a This one could do the job still for a few movies in the last days, but today even that version suddenly without changing ANYTHING to the system gave the same problems.
    Now I'm stuck, with a 1,5GB version of "15 Minutes" and a 1,5 GB version of "Memento", can't cut them into 2 pieces anymore.... Also VCDcutter gives problems, and so does VideoPack5 (Roxio) that cannot handle None-Standard VCD's.
    Greetz
    Mars-L
    I still hope/think the problem is/started with TMPGenc 2.02 and a new (soon to be released ??) version will solve it.
  5. Right. I'm getting the same freeze-up (total!) with TempGenc. System: AMD/Athlon, Via KT133A mboard, 256mg ram, 30gig hd with 3-4gig open space. Got all the ripping (Smartripper/DVD2AVI) done just fine, just can't get the encoding done. So far two other of these freeware encoders are giving me circular commands, anything dependable out there? Thanx,
