I authored a DVD with DVD LAB PRO (normal setting: VTS Menu + Movie). So I have menu and chapters to select. My intention is to have the date and time stamp of the recorded video as a subtitle so that I can choose to turn it on/off. Set default to turn on the subtitle.
The date stamp (*.sub) extracted from the avi file using Dv-Datecode and converted to *.srt using subtitle workshop.Then I created ISO image by TMPGENC DVD Authored.
Load the image in DAemon Tool and play using PowerDVD. If I choose the DVD to play from the first chapter then I will have subtitle turn on but if I choose other chapter I will not have the subtitle appear at all. The subtitle also does not appear if I switch to another chapter during playback of fast forward/rewind
_jelir_
AFAIK, TDA doesn't support subs at all?
/Mats -
Load the image in DAemon Tool and play using PowerDVD. If I choose the DVD to play from the first chapter then I will have subtitle turn on but if I choose other chapter I will not have the subtitle appear at all. The subtitle also does not appear if I switch to another chapter during playback of fast forward/rewind.
If you play the compiled DVD you had before creating the ISO (i.e. the DVD produced by DLP) do the subs work ?
This is how the edited *.sub extracted by Dv-Datecode.(check the bold frame no).
FrameW=720
FrameH=480
FrameRate=29.97
Delay=0
FontName=Arial
FontCharSet=238
FontSize=23
FontStyle=REGULAR
Contour=1
Palette=3210
Alpha=FFF0
OnTop=0
ShowBitmap=0
{0}{1075}08 SEP 04|14:42 PM
{1075}{2531}08 SEP 04|14:50 PM
{2531}{3880}08 SEP 04|14:51 PM
{3880}{3895}08 SEP 04|14:52 PM
{3895}{3907}02 OCT 04|15:56 PM
{3907}{3910}02 OCT 04|15:57 PM
{3910}{5535}02 OCT 04|16:26 PM
{5535}{6901}02 OCT 04|16:27 PM
{6901}{8483}02 OCT 04|16:28 PM
{8483}{10074}02 OCT 04|16:29 PM
{10074}{10638}02 OCT 04|16:30 PM
{10638}{11783}02 OCT 04|16:31 PM
{11783}{12375}02 OCT 04|16:32 PM
{12375}{13657}02 OCT 04|16:33 PM
{13657}{14101}02 OCT 04|16:34 PM
{14101}{15336}02 OCT 04|16:35 PM
{15336}{17133}02 OCT 04|17:05 PM
{17133}{17301}03 OCT 04|09:00 AM
{17301}{22355}06 OCT 04|21:25 PM
{22355}{23820}06 OCT 04|21:30 PM
{23820}{23972}22 OCT 05|01:20 AM
{23972}{28767}22 OCT 04|22:50 PM
{28767}{30741}26 OCT 04|01:00 AM
{30741}{30864}26 OCT 04|01:05 AM
{30864}{30979}26 OCT 04|13:10 PM
{30979}{33088}26 OCT 04|13:15 PM
{33088}{36660}26 OCT 04|18:30 PM
{36660}{37044}29 OCT 04|00:20 AM
{37044}{40793}31 OCT 04|09:20 AM
{40793}{42963}31 OCT 04|09:25 AM
{42963}{43951}09 JAN 05|17:10 PM
{43951}{43960}09 JAN 05|17:15 PM
{44043}{46091}09 JAN 05|17:35 PM
{46091}{48571}09 JAN 05|17:40 PM
{48571}{51022}09 JAN 05|17:45 PM
{51022}{51522}09 JAN 05|17:50 PM
{51522}{56244}09 JAN 05|19:00 PM
{56244}{56348}15 JAN 05|20:50 PM
{56348}{60562}16 JAN 05|15:26 PM
{60562}{62941}16 JAN 05|15:30 PM
{62941}{64825}16 JAN 05|16:03 PM
{64825}{66382}15 MAY 05|09:47 AM
{66382}{70281}15 MAY 05|09:50 AM
{70281}{75392}23 JUL 05|22:25 PM
{75392}{84307}24 JUL 05|10:20 AM
{84307}{84373}06 SEP 05|20:29 PM
{84373}{86914}24 SEP 05|13:24 PM
{86914}{88041}25 SEP 05|13:56 PM
Then I found that if the period of every single line is reduced, then the subs switching (during subtitle selection ON/OFF) will be available without much delay. Somehow during the subs display it will be "blinking" much more since the duration is quite short. Here the examplecompare the bold frame no with the previous sub).
{0}{27}09/08/2004|14:42:03
{27}{57}09/08/2004|14:42:04
{57}{87}09/08/2004|14:42:05
{87}{117}09/08/2004|14:42:06
{117}{147}09/08/2004|14:42:07
{147}{177}09/08/2004|14:42:08
{177}{207}09/08/2004|14:42:09
{207}{237}09/08/2004|14:42:10
{237}{267}09/08/2004|14:42:11
{267}{297}09/08/2004|14:42:12
{297}{327}09/08/2004|14:42:13
{327}{357}09/08/2004|14:42:14
{357}{387}09/08/2004|14:42:15
{387}{417}09/08/2004|14:42:16
{417}{447}09/08/2004|14:42:17
{447}{477}09/08/2004|14:42:18
{477}{507}09/08/2004|14:42:19
{507}{537}09/08/2004|14:42:20
{537}{567}09/08/2004|14:42:21
{567}{597}09/08/2004|14:42:22
{597}{627}09/08/2004|14:42:23
{627}{657}09/08/2004|14:42:24
{657}{687}09/08/2004|14:42:25
{687}{717}09/08/2004|14:42:26
{717}{747}09/08/2004|14:42:27
{747}{777}09/08/2004|14:42:28
{777}{807}09/08/2004|14:42:29
{807}{837}09/08/2004|14:42:30
{837}{867}09/08/2004|14:42:31
{867}{897}09/08/2004|14:42:32
{897}{927}09/08/2004|14:42:33
{927}{957}09/08/2004|14:42:34
{957}{987}09/08/2004|14:42:35
{987}{1017}09/08/2004|14:42:36
{1017}{1046}09/08/2004|14:42:37
{1046}{1075}09/08/2004|14:42:38
{1075}{1081}09/08/2004|14:49:59
{1081}{1111}09/08/2004|14:50:00
{1111}{1141}09/08/2004|14:50:01
{1141}{1171}09/08/2004|14:50:02
{1171}{1201}09/08/2004|14:50:03
{1201}{1231}09/08/2004|14:50:04
{1231}{1261}09/08/2004|14:50:05
{1261}{1291}09/08/2004|14:50:06
{1291}{1321}09/08/2004|14:50:07
{1321}{1351}09/08/2004|14:50:08
{1351}{1381}09/08/2004|14:50:09
{1381}{1411}09/08/2004|14:50:10
{1411}{1441}09/08/2004|14:50:11
{1441}{1471}09/08/2004|14:50:12
{1471}{1501}09/08/2004|14:50:13
{1501}{1531}09/08/2004|14:50:14
{1531}{1561}09/08/2004|14:50:15
{1561}{1591}09/08/2004|14:50:16
{1591}{1621}09/08/2004|14:50:17
{1621}{1651}09/08/2004|14:50:18
{1651}{1675}09/08/2004|14:50:19
{1675}{1692}09/08/2004|14:50:31
{1692}{1722}09/08/2004|14:50:32
{1722}{1752}09/08/2004|14:50:33
{1752}{1782}09/08/2004|14:50:34
{1782}{1812}09/08/2004|14:50:35
{1812}{1842}09/08/2004|14:50:36
{1842}{1872}09/08/2004|14:50:37
{1872}{1902}09/08/2004|14:50:38
{1902}{1932}09/08/2004|14:50:39
{1932}{1962}09/08/2004|14:50:40
{1962}{1992}09/08/2004|14:50:41
{1992}{2022}09/08/2004|14:50:42
{2022}{2052}09/08/2004|14:50:43
{2052}{2082}09/08/2004|14:50:44
{2082}{2112}09/08/2004|14:50:45
{2112}{2142}09/08/2004|14:50:46
{2142}{2172}09/08/2004|14:50:47
{2172}{2202}09/08/2004|14:50:48
{2202}{2232}09/08/2004|14:50:49
{2232}{2262}09/08/2004|14:50:50
{2262}{2292}09/08/2004|14:50:51
{2292}{2322}09/08/2004|14:50:52
{2322}{2352}09/08/2004|14:50:53
{2352}{2382}09/08/2004|14:50:54
{2382}{2411}09/08/2004|14:50:55
{2411}{2441}09/08/2004|14:50:56
{2441}{2471}09/08/2004|14:50:57
{2471}{2501}09/08/2004|14:50:58
{2501}{2531}09/08/2004|14:50:59
{2531}{2561}09/08/2004|14:51:00
{2561}{2591}09/08/2004|14:51:01
{2591}{2621}09/08/2004|14:51:02
{2621}{2651}09/08/2004|14:51:03
{2651}{2681}09/08/2004|14:51:04
{2681}{2711}09/08/2004|14:51:05_jelir_
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 20:41 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 13:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
