I am going nuts here because I know I have done this more. I want to make a DVD that allows you to choose between ac3-2.0 and 5.1 from a menu. I am using Sony DVD-A 3.0. I know under "optimize DVD" you can choose to recompress a second audio stream but I swear I didn't do this last time.
The Sony site tells how to create the menu for it but not how to make the separate streams
Help is appreciated... always.
Results 1 to 11 of 11
The frontiers of our mind are the last place we find, but maybe the first place we should look.
Use your remotes audio button,why do you need a menu? Unless i'm wrong I thought 5.1 was ac3. Do you mean ac3-5.1 and ac3-2.0?
Yes I meant ac3 2.0 and ac3-5.1. Sorry its been a long night. I think you misunderstood though. How do I get the tracks on the DVD in the first place being that you can only select one or the other for output format?
The frontiers of our mind are the last place we find, but maybe the first place we should look. -
I did this earlier this year with Sony DVD-A. I put the DVD in and hit my audio button and could select either option. I realize the 5.1 wasn't truly surround but it was pumping through all speakers and really sounded good.
You should be able to add a second (or more) audio track to the video asset without any problems. However there are certain rules regarding matching audio formats on tracks within the same titleset. Do you have audio on the menu ? Is the audio format on the menu track (track 1 by default) the same as the audio giving you problems ?
Read my blog here.
I don't see any difficulty here. As far as I know DVD Architect lets you add a series of audio files, for instance in English, French, AC-3 5.1 or 2.0 (as guns1inger has previously made it clear). Just add the video file + the main audio file (both should have the same name); select the language for this main audio file (for instance: en; fr, pt, etc..) and then you can browse and add the other audio files for yourself (5.1; 2.0, etc). Burn your DVD; play it and select the audio file you want with your remote control.
I did a brief test with mixed 2 and 5.1 AC3 audio when I wrote my previous post, and there definately is a corrolation between menu audio, track audio, and optimising during prep. If the audio doesn't match, DVDA will try to re-encode one or the other, and does limit the choices. If there is no menu audio there was no problem. I didn't play long enough to see if DVDA was actually making any sense, just enough to see it can cause problems.
Read my blog here.
That's exactly what I don't want. My audio reencoded. I want to include a lpcm in addition to ac3. You just drop it in the timeline under the first audio up there?
And your remote will handle all the rest of the details?
I am under the impression that DVD-A will not recode anything unless you are over size. So stay with in the rates of kbs and you can't miss!
Too easy. -
DVDA shouldn't re-encode if the audio is compliant - no arguments there. But the fact is that it does in certain circumstances, and seems to be inconsistent with what those situations are. Which is one of the reasons I rarely, if ever, use it, and use DLP instead.
Read my blog here.
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 08:03 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 16:16 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
