I just updated to v2.9.5.8 because of the new Sony protection. It fixed my problems on Stealth but not Bewitched. When I open Fab and hit the start button Fab errors out and ask for my email address to send report. Its fabs error report not windows xp. Any ideas on whats going on?
Thanks alot!!
I had no problems with either using DVD Decryptor & AnyDVD 5.4.1.1.
I tried DVD Decrypter and AnyDVD (latest version) and it got all the way to the end then errored out as well. When I tried to use DVD2one it said files where missing.
Thanks -
Sounds like either a dirty disc, or the drive is having problems reading the end of the disc. I've had to run new discs through a Game DR to clean "manufacturing debris" from them - not to mention well placed fingerprints!
As to the chances the drive won't read the disc: I use two drives in my desktop - a Plextor for burning, and an old Toshiba 4X (which produces horrible burns) for reading only - Why, the Plextor just can't get to the end everytime. I'd read it in another forum that good burners do not necessarily make good readers, and have to admit it's true.
A machine that I built for a friend (2 NEC 3520's) couldn't read some CDRWs burned on that machine. He gave the discs to me to check out, and I did recover his data on the Toshiba drive - the Plextor couldn't see anything.
If you have a DVD-ROM drive available, try a rip with that - if it gets to the end of the disc without issues, you might want to consider installing a DVDROM drive in your machine.
I hope this helps. -
Thanks Classfour, good info. I don't have an extra DVD-Rom. All I have is a NEC 3540 burner. I have never had a problem reading any disk yet. It could be like you said scratched from the kids. I tried cleaning it with a disk cloth but did not work. How well does those CD doctors/cleaners work? What is a good brand to look into?
Again thanks for you help! -
Bewitched is the first one to stump me in months.
snappy phrase
I don't know what you're talking about.
DVD Fab 8
By eastert in forum DVD RippingReplies: 7Last Post: 4th Jan 2011, 22:14 -
dvd fab
By mahapatra in forum Video ConversionReplies: 2Last Post: 13th Mar 2010, 02:39 -
DVD Fab 6.0.2.2
By jyeh74 in forum DVD RippingReplies: 4Last Post: 7th Jul 2009, 14:59 -
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 03:39 -
DVD Fab
By mikes01 in forum Authoring (DVD)Replies: 8Last Post: 6th Jan 2008, 15:14
