I've twice recorded a few kiddie shows for my children and I cannot get either dvd to play on my car's dvd player. The car dvd player only accepts DVD-VIDEO and DVD-R discs. I recorded to my usual dvd-r media and I've tried all the following:
1. Take cyberhome dvd+R/W disc, recode to DVD-R disc using my pc
and dvd-shrink.
2. Record directly to dvd-r using cyberhome.
3. Strip out menus and leave just video
The car's dvd player freezes up a few seconds into playing. I'm thinking that the cyberhome dvd format is sloppy. If that is the problem, does anyone know of a way to fix this problem? Any other ideas?
Thanks!
Rick
Have you tried the DVD-R you made in any other player besides your car DVD player?
If you don't have other players, I would take your DVD-R to a store like Best Buy or Circuit City and try it in the players they have.
The other option is to try another DVD-R that maybe a friend has made in your car's DVD player and see if it will play that DVD-R.
You need to isolate to whether it is a problem with the DVD-R you made or whether your car's DVD player having problems with playing DVD-R.
Also, which brand of DVD-R are you using?
Check out http://www.nomorecoasters.com for valuable information about buying good media. I myself only buy made-in-Japan disks. -
Thanks for the suggestions! The problem was with the format of the cyberhome produced discs. I ripped and re-authored the discs with Nero and I can now play the discs in the van.
Playing HD MP4 Files From Disc Playback Issues?
By zombie1 in forum DVD & Blu-ray WritersReplies: 5Last Post: 5th Nov 2011, 12:41 -
Playing a 30p AVCHD disc
By Michael33 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2011, 12:40 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 07:34 -
problem with cyberhome ch-dvr player/recorder
By kayjay3k in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 17:27
