  1. Hi, I'm wondering what the difference is between GPRM & SPRM as when working with DVDremake all are reffered to as [R]. So when I set one I think I'm using a GPRM as it's just a memory and SPRM are specific for certain codes no? Or am I totally clueless?
    There are no stupid questions, only stupid people.
    Nov 2004
    Las Vegas
    You can write to a GPRM register, the SPRM registers are read only. The SPRM registers hold information that's specific to the Dvd Player (like the region code, parental level, etc). If you are interested, here's a link to a breakdown of the what the SPRM registers refer to.
  3. So how can I be sure that when I make a conditional compare that it is a SPRM that's used or a GPRM? As both are only pointed to as [R].
  4. R[X] - is always GPRM. All SPRMS are named in DvdReMake Pro, so you will see something like R[0] = vmg_title.
    http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
  5. SPRM registers are read only
    No, not all.
    You can set the SPRM for audio stream or subtitles stream or ...
    Hav a look here:
    http://www.dvd-replica.com/DVD/sprm.php
  6. OK, thanks all....
    BTW, Dimad, great software!
    Next an add button feature? And a trace function like in PGCedit.
    No harm in asking ey.
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I thought there was some sort of trace function in DRM?
  8. You are both right actually. There is no step-by-step trace function yet - it is coming. But there is a "Open destination" function ( http://www.dimadsoft.com/dvdremakepro/new_features_v3.php#jump ) that can be used to go through Link/Jump/Call commands and trace DVD navigation.
