    Oct 2005
    Canada
    Hi,
    I have a Quicktime movie that was created using IMovie on a Mac. It plays fine in Quicktime on a Mac but not on a PC. I have Quicktime Pro 7 on both Mac and PC. The .mov is DVCPro 50 NTSC with audio. Any ideas?
    Thanks.
  2. I believe the DVCPro 50 codec only comes with Final Cut. You may have to export out a straight DV file.
    Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
    Your source for iMovie answers and what not! ;-)
    Oct 2005
    Canada
    I donwloaded MainConcept DVCPRO 25/50 codec and Avid's DVCPRO 50 codec but the same thing happens.
    Oct 2005
    Canada
    I just found out that no matter what compression codec you use, if your file is a .MOV then it will always use Quicktime's codecs. So my problem is that Quicktime on PC does not have a DVCPRO 50 codec. Even if I download all the DVCPRO 50 codecs for Windows XP, it is irrelevant because I am using a .MOV.
