I want to take a large size MPEG-2 video recorded from TV and make it into a much smaller
animated GIF. How would I do this? What tools would I need?
Results 1 to 11 of 11
virtualdub-mpeg2 and save as image sequence, open in a gif animation tool like animation shop, adobe photoshop imageready
or read
https://www.videohelp.com/forum/viewtopic.php?t=233640&highlight= -
Just a quick question. I see the File -> Save image sequence... in VirtualDub-MPEG 1.611,
and I was able to export out as a sequence of TGA files. It loaded my MPEG-2 without problems.
Does this program have to ability to do a batch frame resize of 704x480 to something
smaller? Or does ImageReady have a batch resize option? -
Is there a way to automatically import like 100 TGAs as animation frames into ImageReady?
It seems you have to add each frame by hand. If there's no way to add multiple images
then ImageReady is not very good at all. -
file->import->folder as frames?
http://www.heathrowe.com/tuts/importasframes.asp
you can also import avi in imageready, so you could convert to avi with virtualdub-mpeg2...don't know what video codecs it supports though. -
Found it again! This option is kinda not-so-obvious. Had to dig through the help files:
File -> Import -> Folder As Frames... -
i found it using gooooooogle....imageready import image sequence
Thanks, I missed your post by 1 second.
All I have is one question and I'm done.
The GIF created by ImageReady is too slow. Is there a way to speed it up?
All frames are already set at (0 sec/No Delay). -
Well, I thought I could speed it up by deleting every other frame, but now, not only does it still
look slow, it looks choppy as well.
Maybe I have to go back to VirtualDub and speed it up there? 2x faster?
Animated Gif Maker
By budwzr in forum EditingReplies: 12Last Post: 10th Jan 2012, 11:09 -
Requesting help to make an animated gif!
By kSOS in forum Newbie / General discussionsReplies: 6Last Post: 5th Apr 2010, 13:39 -
animated gif
By snafubaby in forum Newbie / General discussionsReplies: 14Last Post: 27th Jan 2008, 13:41 -
AVI to animated GIF
By snafubaby in forum Video ConversionReplies: 10Last Post: 12th Nov 2007, 22:33 -
how do i slow down an animated gif?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2007, 01:12
