    Nov 2005
    Russian Federation
    Hi ppl,
    is it possible to generate chapter markers automatically, for example every 5 minutes, in Sony DVD Architect 3? I'm really lazy to do that myself for a 1.45 min movie. I only could find in the manual how to add chapters manually.
  2. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    I "guess" if the video file is long enough (maybe longer than 10 minutes), DVD Architect will create those chapters automatically. Try to author the DVD (insert a DVD + or - RW to make a test) and then when you play the movie (s), press NEXT on your remote control unit. If pressing NEXT plays the next movie on the menu, probably the video file was shorter (for instance) than 10 minutes. On the other hand you can create the chapters yourself - it's so easy! Mouse+Left Click 2 times.
