Hello, im trying to fix an audio file that is not split (L/R) channels, how
can i make it that way..so i can edit it better.
E.
You didn't say what type of file, but.... I use VirtualDub Mod. It can input AVI or MPEG. Save out the audio as a WAV, put it into an audio editor.
I use the freeware Audacity. Copy and paste the one channel into the second channel. Add effects if you like, save it as a stereo WAV and use that with your video. You can mux it back into the video with VD Mod or use it in your encoder for the new audio source.
If it's just a audio file, use the second paragraph instructions. Works just like a word processor, copy and paste.
