Thanks to you guys I have learned how to paste subtitles in an .avi file, but not i have another problem, the pasted subtitles are too small, so i need to meke 'em bigger.
Does anyone know how to change size on an already created .srt file; I tried Titlelab but the result is unreadeable by VLC.
Thanks in advance,
M.
Go here and get
Subtitler 1.20.5 for Mac
follow the instructions, then resave the file
in the .srt format."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
thanx man, you always have the answer.
But the link is broken or something, i tried getting it from version tracker but the link does not work, any idea where to find Subtitler 1.20.5.?
I even tried on bchris.dyndns.org the developers site, but it's not working.
Cheers,
M -
I just tried the link to versiontracker.com and it downloaded just fine....but slowly.
yeap you are right, something must be wrong with my connection, now i am downloading it.
Thanks both of you,
M. -
My dear friends, there is something i am doing wrong or not doing at all.
I got Subtitler 1.20.5 and I can open my srt. files on it, and then save them as SubRip but I do not know how to make tham bigger, because when I try to embed the subtitles in D-Vision with an .avi file, they are too small.
I want them bigger so when i watch it on tv then look normal.
Any clues what am I missing?
Cheers, -
Manolo,
Subtitler Help File,
under the Preferences Link,
shows CLEARLY how to set size and font Choice.
try that and let us know.
Urban Mac User -
Terryj,
I did what you told me, went to preferences on Subtitler, select a new font and a new size (bigger), than I saved as SubRip in all the 5 possibles encodings. (MicroDvd or DVD Studio pro makes .sub files)
Then open D-Vision to encode my avi. and embed the .srt file, but when I preview it the subtitles size and font are always the same (pretty small) no matter wich .srt file i use (ISO 8859-1 or 7; UTF 16 or 8 and MacRoman).
So, i am feeling lost here, thanks.
M.
Question about how to modify exe file
By jimdagys in forum ComputerReplies: 9Last Post: 29th Oct 2011, 17:59 -
How to modify .srt subtitle FPS time duration??
By iqbal88 in forum SubtitleReplies: 2Last Post: 8th Aug 2011, 13:28 -
Trying to modify .VOB file - why didn't this work?
By brassplyer in forum Authoring (DVD)Replies: 8Last Post: 7th Feb 2011, 22:03 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22
