    Nov 2005
    I've been looking thru many posts here (for last 8 hrs) and found various free pgms, such as BeSweet (which I just tried via the BeLight GUI)...the 3 min input VOB (extracted from a DVD of a meeting) created a file of 3145KB...which was at 334kbps, as I understand it...
    When I created a test (spoken input) WMA file via WinMediaEncoder, I was able to select voice quality of 19kbps, which seems more appropriate given that audio on both is just voice, and output file was 250KB...
    So what options should I use on BeSweet to get a similar tiny file? Because 3MB for 3 min is way too big given that my goal is to create a podcast type file of maybe 2hrs of input.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    WMA is more compressive than MP3 by design, but you should still be able to choose 32kbps in Belight.
    If in doubt, Google it.
    Dec 2004
    Australia
    For low bitrates aac (he/ps) is good or vorbis. For pure voice encoding a dedicated encoder like Speex should do a better job. Still a 32k mp3 if it is just speech should sound ok. You will need to resample down from 48KHz though although the encoder should do that automatically.
    Nov 2005
    So I would do so in the SSRC "sampling rate" option, correct? And what value might you suggest instead of 44100 default? (Update: Tried using this option...get error 47 with lame.dll - quitting)
    I'm using the quality option 30 which says 96kbps. Should I switch/try bitrate option so I can get it to the 32 you mentioned? (Tried this...got same error 47! <-- UPD: had to set use constant bitrate to work)
    2nd update: tried 32 kbps...got output file of 751KB which is MUCH better...quality seems ok!
    3rd update: The 751KB file lost about half the volume...so what did I muck up?
