    Apr 2005
    England
    Hi,
    What is the standard pixel size for dvd's. I use win avi and when i convert my avi's to mpeg2's what size under advanced options should i put? At the moment i've just been using the max settings but because of this i get error msg's when working with the mpeg2 in DVDlab. I know you can enable to allow non-dvd sizes but I'd rather have the proper size.
    cheers
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    if NTSC, 720 x 480. If PAL, 720 x 576. More details under "What is DVD ?" (top left).
    If in doubt, Google it.
