  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    How can I set my keyboard to be used as short cuts to get online. What I want to do use say the letter (V) as a short cut to get me to videohelp. Is there a way to do this?
    What We Do In Life, Echoes In Eternity....
  2. Yes. You can remap your keyboard or use macros. There are numerous software apps out there, just do a search. You will be better off using the function keys or a combo of shift +/ctrl +/alt +
    ...otherwise you can no longer type the letter "v" while running the macro
    Aug 2005
    Nepean, Ontario
    Right-click on your desktop, select New, Shortcut.
    In the location, type the URL for videohelp (for example), press next and give it a name.
    Right click on the new desktop shortcut, and select properties.
    There is a place where you can enter a shortcut.
    As offline said, you are better off using a combination of Shift, Alt, or Ctrl keys.
    For example, on my work laptop I have a shortcut assigned to launch the VPN client. I simply press the Ctrl+Alt+V key combination and it launches the VPN client.
