There is an option in mkvmerge GUI for the audio sections of mkv files. The option is a checkbox that says AAC is SBR/HE-AAC/AAC+. If I see that one of my files has audio with A_AAC/MPEG4/LC/SBR, should I check the option when merging the file?
Is it bad if I did check it for one of the mkv files I had? Or does it not affect the audio quality at all?
If a decoder doesn't know that it is he-aac (when it is), then it will decode without the SBR part. This will badly effect the audio quality. Fact is that some decoders might get it right anyway. Plus from the sounds of it all you are doing is ticking a box that essentially would have been auto-ticked anyway. Like I said, you shouldn't need to worry about the option unless you are muxing a raw aac file.
Muxing with mkvmerge
By sharu006 in forum Video ConversionReplies: 7Last Post: 14th Dec 2012, 11:48 -
An Mkvmerge question
By call4jim in forum SubtitleReplies: 3Last Post: 25th Apr 2011, 07:25 -
Need Help with MKVMerge 4.2.0
By muramasa007 in forum Newbie / General discussionsReplies: 5Last Post: 31st Aug 2010, 19:46 -
Splitting with MKVmerge
By carlmart in forum Video ConversionReplies: 6Last Post: 22nd Dec 2009, 19:59 -
mkvmerge options
By magmo in forum Blu-ray RippingReplies: 3Last Post: 20th Jul 2009, 09:58
