I wonder if I can convert the whole DVD from NTCS to PAL and keep the chapters, subtitles and all in one go.
Is there an application that can do that? I tried ffmpeg and it looked as it could not
Fast reply appreciated as I have to finish tonight,, hehe![]()
Mpeg2works 4 will do what you require, not sure how long it would take to convert a dvd.
Normally NTSC DVD's will work on European DVD players and TV's anyway.
Stu. -
I have Mpeg2works and did not find a way to convert the whole DVD with all the BUP and IFO files included.
You can not covert the DVD without building the menus again.
In Virtual PC:
I tried the "Patch" method with IFOedit ... did not work.
So I improvised this method with converting the IFO files (in V PC) and converted the VOB files with Mpeg2Works 4... put it all together .... no luck.
So for NTSC to PAL the PAL DVD players should play them fine and if want PAL to NTSC get a cheap DVD player from Walmart (Cyberhome) it will play the PAL dvds.
If you are set on converting it for fun then .....
use YADEX (you can see which are menus and which are movie files) to rip the segments into VOB's and convert with Mpeg2Works. If you use DVD Studio Pro you will have to convert the sound to AIFF then import and happy building.
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
Current DVD Recorders in both PAL+NTCS available?
By 1234567 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2010, 18:30 -
convert pal dvd to ntsc, but different
By atomicrabbit in forum EditingReplies: 5Last Post: 12th Jan 2008, 04:48 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13 -
How to convert PAL DVD to NTSC?
By tomterrifk in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2007, 16:35
