I have made a clip in Adobe Premier Pro 1.5.
I have use for some effects flash and I have convert the swf to video format with flashant swf2video pro 1.0. (I use divX 5.2.1 codec )
I am not content with the resolution on the DVD.
I use mpeg2 for encoding the clip, 9800kb/s.
I have a Pentium 4 3.2 64bit with 3GB Ram, 256 NVIDIA GeForce 6600.
I am new so I don’t know if I am doing something wrong in the encoding procedure or my computer components are not very good fore that job?
The problem is with some logos companies. The logos are in high resolution. The Problem is in the Clip you hardly recognize them.
Some one told me that the graphics with slim lines they have to be in vector format. It’s any one have an opinion for that?
I also want to ask if anyone have see better resolution with the flashant swf2video premier Plug-in?
I suggest you post sample frames from your source and DVD.
But just as a guess... DVD video is low resolution compared to a computer monitor. It may just be that the text is too small for DVD resolution. -
Exactly!
Spyro, in case you wish to convert PC stuff to DVD, always keep in mind how this gonna look on 720 x 576...La Linea by Osvaldo Cavandoli
I advise you to use flash to video encoder by XXXXXX,instead of swf2video.It converts without any quality loss and easy to manage.I've found it from google.Originally Posted by spyros
Samsung CRT sp43t7hlx/shi - Resolution problems in w7
By runkz in forum ComputerReplies: 1Last Post: 27th Nov 2009, 02:31 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
sorenson squeeze resolution and fps problems
By phpmysql348 in forum Video ConversionReplies: 7Last Post: 7th Sep 2008, 22:46 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
DVD resolution problems / confusion
By Laurels in forum MacReplies: 2Last Post: 5th Jun 2008, 03:57
