I've had a camcorder for 12 months now but only just bought a firerwire card. I'm running windows xp and it picks the camera up no problem, but as soon as i try and use dvd movie factory or dvd santa i get this error message
failedto connect to driver sony-MSDV
Does anyoine know what the problem ishere and a solutionwould be most welcome. The model of the camcorder is sony DCH-HC14E.![]()
Try Windows Movie Maker or WinDV to test.
http://www.kiva.org/about -
Assuming you've covered the basics, (i.e. turned the camcorder on, installed the most up to date drivers for the firewire card), could be a DirectX problem. You might want to try downloading and installing the latest version of DirectX.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Done all of the above, still no joy, still get the message failed to connect to driver sony - msdv
Still think it may be a DirectX problem, try reregistering the file qdv.dll (this controls capture.)
In Windows click Start>Run and type
regsvr32 %windir%\system32\qdv.dll
You should get a dialog box pop up saying if it succeded. You might also try reregistering qcap.dll as well."Just another sheep boy, duck call, swan
ive had a problem like this wiht Sony too.
And i changed Win XP 1 to XP2. And the camcorder working good wiht XP pack 2.
If your Windows is pack 1,check XP 2 too. -
You haven't set the control method. In Moviefactory you have an option for Device Control which defaults to None, change it to MS 1394 and it should work.
Sony CCD-TRV53 Camcorder Problem! :s
By PetiteCerise in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Nov 2011, 13:20 -
Sony camcorder battery question
By BuhBuh-Ray in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2010, 02:15 -
How about the Sony HDR-XR150 Camcorder?
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Aug 2010, 18:07 -
Problem: No dubbing from Sony HD camcorder to hard drive of HDD
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Feb 2010, 23:43 -
sony camcorder lcd problem
By Wizard23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Feb 2008, 21:27
