i have some XVID.avi's that playback "squished" at 4:3 when it should have been encoded for 16:9 -- is there any way to take the sqeezed 4:3 video and convert it to the proper 16:9 so i can then use TOAST 7.0.1 to make a playable DVDR in 16:9?
i do not have the original source video that the "incorrect aspect ratio" video was made from.
i can't play avi's on my TV DVDplayer, which is why after correcting the aspect ratio, i want to burn to DVDR.
is it possible using a MAC?
Change the frame size (width) in QuickTime (Cmd-J, Video track, Visual Settings, Scaled Size) to the correct aspect ratio, save as reference movie, and feed that to Toast.
danke!
jeez... it sounds so simple that i feel embarrassed to have even asked!
thanx! -
Not sure your problem is the one describe on the page, but just look at it.
tutorial google translation
The english translation have not been done yet, so it's a google automatic translation.
If you can read french, the original page is here:
http://www.mydvdedit.com/viewtutorial.php?t=27f
Jérôme. -
The english translation is now available here:
http://www.mydvdedit.com/viewtutorial.php?t=27e
Thanks Annette.
Jérôme. -
Nice guide Jerome (nice app too, we love you
By the way, you might want to change 'not' to 'now' in your post above to avoid any confusion. -
Use ffmpegX (I use v0.0.9s although others swear by 0.0.9t; see the ffmpegx forum for why). Set the proper pixel size there. 16:9 should work out to 720x360 (it's actually 640x360 but we're doing DVD and NTSC DVD is 720 pixels wide).
Or, if you have the MPEG2 codec from Apple, export from QT Pro Player but remember to clck the 16:9 checkbox! No amount of pixel twiddling will help unless you have this set properly.
Or, use MPEG Streamclip and export to mpeg2 using the desired ratio (720x360). This app is free and usually works very well for me.
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
AVI/Xvid->MP4/Xvid w/o recompressing?
By chconnor in forum Video ConversionReplies: 15Last Post: 9th Feb 2010, 17:47 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
