i tried to encode to DVD-lo to make a DVD. With small sizes .avi there's no problem at al. And only once it worked with a big size .avi. But now i don't ge the folders AUDIO and VIDEO. Only a .m2v and that's it.
Here is the info of an encoded file, maybe somebody can help me out?
Encoding started on Tue Nov 15 20:34:23 CET 2005
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 720x576 pixels (622080 bytes)
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x576, take 720x576+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x576, 720x576 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x576 pixels (622080 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm PAL
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/kiona/Desktop/Triple X 2 - State of the Union.avi.ff.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 3746 KBit/s
INFO: [mpeg2enc] Quality factor: 5 (Quantisation = 5) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 136007!
INFO: [mpeg2enc] Guesstimated final muxed size = 1293144842
error: movie contains no audio tracks!
Help is needed.
thanks.
the source format in the summary tab is:
mp3, 48000 Hz, stereo, 32 kb/s
i'll try to decode with mplayer
earlier with an .avi file it worked, but now i tried an .MOV file an i get an failed message. This is what te Info sais:
Encoding started on Wed Nov 16 11:33:56 CET 2005
/DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff/
/DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff/: File exists
-f 5 -b 3538 -q 5 -B 260 -V 230 -a 2
-F 3
MPlayer dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV' '-aid' '0'
get_path('font/font.desc') -> '/Users/kiona/.mplayer/font/font.desc'
font: can't open file: /Users/kiona/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/kiona/.mplayer/input.conf'
Can't open input config file /Users/kiona/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
get_path('Rowanstofzuigt08:2005.MOV.conf') -> '/Users/kiona/.mplayer/Rowanstofzuigt08:2005.MOV.conf'
Playing /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.
[file] File size is 218889052 bytes
STREAM: [file] /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for Nullsoft Streaming Video
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV ext: .MOV
Trying demuxer 7 based on filename extension
Checking for MOV
Quicktime/MOV file format detected.
tkhd len=84 ver=0 flags=0x0 id=1 dur=125080 lay=0 vol=0
MOV track #0: 209 chunks, 6254 samples
pts=125080 scale=600 time=208.467
==> Found video stream: 0
Image size: 640 x 480 (24 bpp)
Display size: 640 x 480
Fourcc: gepj Codec: 'Photo - JPEG'
tkhd len=84 ver=0 flags=0x0 id=2 dur=125080 lay=0 vol=256
INFO: [yuvscaler] SVCD output format requested in PAL/SECAM norm
INFO: [yuvscaler] input: frame size: 640x480 pixels (460800 bytes)
INFO: [yuvscaler] input: frame rate: 14999999/500000 fps (~29.999998)
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 640x480, take 640x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x408, 720x544 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
k #1: 209 chunks, 0 samples
pts=1641675 scale=7875 time=208.467
==> Found audio stream: 1
Audio bits: 16 chans: 1 rate: 7875
Fourcc: sowt
Quicktime Clip Info:
Format: Digital Camera
Info: KONICA MINOLTA DIGITAL CAMERA
VIDEO: [gepj] 640x480 24bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x6765706A size:640x480 fps:30.00 ftime:=0.0333
INFO: [yuvscaler] black lines: 68 above and 68 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 30.000 fps
INFO: [yuvscaler] Scaling ratio for width is 8 to 9
INFO: [yuvscaler] and is 20 to 17 for height
ub/'
get_path('default.sub') -> '/Users/kiona/.mplayer/default.sub'
Using (default) progressive frame mode.============================================= =============================
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffmjpeg] vfm:ffmpeg (FFmpeg MJPEG decoder)
Audio: no sound
Freeing 0 unused audio chunks.
Starting playback...
INFO: [yuvscaler] output: frame size: 720x544 pixels (587520 bytes)
INFO: [yuvscaler] output: frame rate: 14999999/500000 fps (~29.999998)
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Selecting SVCD output profile
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
000
VDec: vo config request - 640 x 480 (preferred csp: Planar 422P)
Trying filter chain: vo
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
Trying filter chain: scale vo
VDec: using Planar 422P as output csp (no 1)
Movie-Aspect is undefined - no prescaling applied.
VO Config (640x480->640x480,flags=0,'MPlayer',0x50323234)
SwScaler: reducing / aligning filtersize 1 -> 1
g2enc] Encoding MPEG-2 video to /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff.mpv
INFO: [mpeg2enc] Vertical size: 544 pel
INFO: [mpeg2enc] Bitrate: 3538 KBit/s
SwScaler: reducing / aligning filtersize 9 -> 8
SwScaler: BICUBIC scaler, from Planar 422P to Planar YV12 using AltiVec
SwScaler: using C scaler for horizontal scaling
SwScaler: using 1-tap C "scaler" for vertical scaling (YV12 like)
SwScaler: 640x480 -> 640x480
REQ: flags=0x407 req=0x0
VO: [yuv4mpeg] 640x480 => 640x480 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
mage_t, 640x480x16bpp YUV planar, 614400 bytes
*** [vo] Allocating mp_image_t, 640x480x12bpp YUV planar, 460800 bytes
*** [scale] Allocating mp_image_t, 640x480x16bpp YUV planar, 614400 bytes
number 670
% 0.0% 0 0
act= 92354.5
8 17% 635% 0.0% 0 0
l act= 94147.6
5
nd 738 P quant=11.56 total act=104843.2
% 0.0% 0 0
t=10.64 total act=105848.6
nd 751 B quant=6.80 total act=106791.6
7 17% 702% 0.0% 0 0
total act=107682.2
mber 782
64% 0.0% 0 0
al act=367525.2
67% 0.0% 0 0
number 2651
end 2635 I quant=8.12 total act=373127.2
.5
678 17% 667% 0.0% 0 0
15% 0.0% 0 0
ant=11.86 total act=422454.9
.67 total act=423370.7
mber 3046
15% 0.0% 0 0
B quant=10.68 total act=426248.8
t=11.98 total act=427148.5
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
uninit video: ffmpeg
Exiting... (End of file)
INFO: [yuvscaler] Normal exit: end of stream with frame number 6255!
INFO: [mpeg2enc] Guesstimated final muxed size = 116395331
wait, encoding to mp2 audio with mp2enc...
/Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 213: /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff//audiodump.wav: No such file or directory
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /DATA/Movies/08-2005/Rowanstofzuigt08:2005.MOV.ff.mpa for reading.
Why did it work on a .AVi file and not on a .MOV file?
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Help with audio encoding
By tooonami in forum LinuxReplies: 1Last Post: 11th Jul 2009, 18:55 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
