Which USB capture device?
Of course it plays well on regular tv. Your tv isn't a digital capture device and doesn't work like one.
That's about right. Some cost more.
If you believe that, I have a huge landmark bridge in Brooklyn I'll sell you cheap. It's worth a fortune. Fully functional. Check this website: http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html. They also have a marketplace forum with refurb'd and working VCRs and other hardware, including tbc's.
It has a built-in line-level tbc. Not a frame-level tbc. You need both. And $100 is pretty cheap for that unit.
Yes.
A frame-level tbc fixes overall signal timing between frames to help ensure a/v sync and prevent dropped/inserted frames or skipping.
A line-level tbc fixes in-frame scanline timing errors that result in image distortion and jitter.
See above
No. But you can use a very few legacy DVD recorders as pass-thru units, for both line-level and frame tbc circuits from your VCR to your capture card. The models usually recommended are Panasonic DMR-ES10 and ES15. Not all DVD recorders can be used as tbc pass-thru, and most of the others that can are pretty poor specimens. https://forum.videohelp.com/threads/319420-Who-uses-a-DVD-recorder-as-a-line-TBC-and-what-do-you-use
Yep, it's mighty old. And everything here has been repeated hundreds of times in this forum since this thread first appeared.
More questions? I suggest starting a new thread.
Good luck.
Results 31 to 35 of 35
- My sister Ann's brother
Wow, thank you for the fast response to this old thread! Your advise is greatly appreciated.
I ordered the Diamond Multimedia USB 2.0 Video Capture Device For MAC TV Tuners and Video Capture VC500MAC. It was through Amazon Prime so I figure that if it does not do the job as expected, I can easily return it.
I will keep looking for a quality TBC. -
An external TBC cleans the signal. Without signal cleaning, capture card will reject it or give errors (dropped frames, etc).
An internal line/field TBC (tied to DNR) cleans the image.
Not the same.
You need both good VCR and good external TBC.
Quality non-flawed external TBC will run about $400, yes.
VCR in good condition will run about $300+.
This post was started in 2005. It's now 2017. You need to stay far, far away from this VCR model. It was passable at best then, but should be entirely avoided now. It will have problems, even if claimed otherwise by the eBay goon/seller. Caps are dried, heads worn/shot, etc. (Good grief, now I'm sounding like Orsetto!) This isn't what you want.
Alternative marketplace for good used gear = http://www.digitalFAQ.com/forum/marketplace/Want my help? Ask here! (not via PM!)
Thank you. You guys are saving me the hassle of finding this stuff out myself the hard way. I appreciate the advice.
I have the capture card now and I'm going to give it a try on Sat night / Sunday, looking for missed frames, etc. before I just go for it and buy a TBC.
If I buy a TBC and keep it in great condition, is there a reasonable expectation that I should be able to sell when I'm done for most of what I paid for it? -
Panasonic AG-7750 Playback Problems
By howardd1965 in forum RestorationReplies: 23Last Post: 8th Apr 2021, 23:36 -
How much is a Panasonic NV-FS200 / AG1980 worth now?
By zeroprobe in forum RestorationReplies: 11Last Post: 24th Nov 2013, 11:54 -
Panasonic NV-FS 200. What's a good matching pair worth?
By Rich Joy in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2011, 12:40 -
Looking to sell my older Panasonic TH-42PD50U Plasma TV Whats these worth
By marionr26 in forum DVB / IPTVReplies: 1Last Post: 8th Jan 2010, 21:35 -
Is an old Pan AG-7750 worth spending a few bucks on?
By brejdol in forum RestorationReplies: 3Last Post: 5th May 2007, 03:54
