So I'm using this program for the 1st time & I'm trying to add chapters using the chapter cut edit. I'm watching the clip but I can't hear any thing so it's had to add chapters where I want them. The speaker tap next to the other ones(play,stap fast Forward ext) doesn't work. Please help!! Thanks,Mike
My guess is that your audio is AC3 and that you don't have the AC3 plug-in.
The audio is dolby digital AC-3 48000hz 2 ch
I don't see why it won't work. I created a menue & than exported it over to dvdremaker & edited it(added chapters) & no problem. It would be nice not to have to use 2 programs though.
In TMPGEnc the speaker icon that shoulsd let me turn on audio isn't even accessable
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
Help with output after editing with tmpgenc 4.0 xpress
By uka100 in forum EditingReplies: 2Last Post: 14th May 2008, 20:30 -
Editing w/ TMPGEnc 4.0 Xpress
By JOHNTOUPS in forum EditingReplies: 7Last Post: 20th Feb 2008, 15:27 -
VirtualDub + New Audio + Editing + Audio Intact?
By hech54 in forum EditingReplies: 6Last Post: 16th Aug 2007, 14:57 -
Editing Audio
By funnyclown11 in forum AudioReplies: 10Last Post: 4th Jul 2007, 09:12
