Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Nov 2005
    I'm still getting used to W2K (prior PC was W98SE) so sometimes I'm not sure when I must use Admin vs User. I attempted to install the AC-3 ACM codec when in user mode but just get a "Installation Failed" error.
    I realize I could just try it, but wanted to post here to document your answer for others who may have same question. Thanks!
    Apr 2004
    Miskatonic U
    You decided to wait for answer that might takes hours to be posted, instead of trying out a 30 second exercise ? *shakes head in disbelief and wanders away*
    Read my blog here.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    At least said user has enough sense (or most probably does not know how to) to not make themselves a local administrator and keep the admin rights account for only when required.
    Imagine all that power !
    As for the question, what's say you try it, and document what happens back here in the thread for the benefit of others ?
    If in doubt, Google it.
    Nov 2005
    Part of reason I posted was: The error message did NOT mention the possible cause, as other software does when they say something like "Must have Admin rights" so wasn't sure if it was that or something else...also, on this site is a number of helpful guides...I thought having this detail in any appropriate place might be helpful ...and that maybe, any guide/software author would see this and document it on this/their site...
    I have yet to switch over to Admin and try it...given that I mostly avoid it by using "Run As" for other EXE installs, but I presume that can't happen with an INF install.
