I managed to get my audio sorted in goldwave. Just need to know how to make it play continuously while swaping menus etc. any ideas???
You can't if you jump from menu to menu. Each menu can have it's own audio. Another way of looking at that is that you can't share audio.
What you can do is create an audio track that has natural loop points (with pleasant fade ins and outs) and have each menu last the length of an audio loop. When played, a jump should be momentary and it'll sound like it would were it to normally loop on itself. That's what the Studios do.
Future Note: HD DVD and Blu-Ray, once in use, should give you more creative latitude in this area.
GFD: continuous play in Audio Titlesets
By AlanHK in forum Authoring (DVD)Replies: 6Last Post: 3rd Aug 2010, 16:33 -
Continuous audio throughout menus
By dth122 in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 23:34 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
Longest Continuous Capture?
By quicksilverg4 in forum Capturing and VCRReplies: 9Last Post: 19th Apr 2008, 09:34 -
continuous capture
By AJwonder in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2008, 14:36
