I need to get a program that can burn anytype of file to a DVD without it saying not a compatible file. for instance I have two types of files: 1 is a mpeg and the other is a .bin and .cue file. Well both of those files together have a movie on them and I want to burn those two files on two one dvd. What program do I need to use?![]()
I have another question can I just derictly burn a .bin and .cue file to a dvd and a movie will play in a dvd player? what about if I put a mpeg file on a dvd also will it play a movie in the home dvd player?
Well, a .cue file goes with a .bin file and it contains the "instructions" (roughly speaking) on how to turn the .bin file into a valid CD or DVD (again, I'm being very general here!). So yeah, if you have a valid bin/cue set, and open the cue file with, say, Nero Burning ROM (my personal burning program but there are others), Nero will read that cue file and know what to do -- you just press the "Burn (DVD or CD)" button then.
As for whether or not the resulting DVD will play in your DVD player depends on whether the image was valid to begin with, and then on some variables involving your media, cd-burner, playback device, blah blah blah.
But yeah, for the most part, if you've got a valid bin/cue set, burning a DVD is as easy as:
1) Open cue file with Nero (or some other burning software)
2) Burn resulting DVD
As for your mpeg file, assuming it's an mpeg2 file, you'll need to "author" the file into DVD-playable format (i.e. VOBs, .ifo files, VIDEO_TS folders, etc.) using some form of DVD authoring software. Nero can, depending on your luck, also do this for you (or more accurately, Nerovision Express, part of the full Nero suite, can do this for you).
There's some freeware and shareware software that'll burn bin/cue files, as well as author DVDs, but I'm lazy and somebody else can tell you about those, they'll post soon.
Easy prgram that converts HDTV TS streams to x264??
By peggypwr1 in forum Newbie / General discussionsReplies: 16Last Post: 4th Jun 2011, 05:02 -
Good bd-r burning software
By mol3000 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Mar 2009, 11:46 -
Is the Hp DVD740 a good choice for basic DVD burning
By EthansMom1030 in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Feb 2009, 10:03 -
Good file burning software.
By MeekloBraca in forum ComputerReplies: 6Last Post: 8th Oct 2007, 09:06 -
what is a good burning speed???
By offensekilla in forum Authoring (DVD)Replies: 6Last Post: 29th Aug 2007, 02:08
