Checking out the MCE Technologies site for DVD burner for the Cube I came across this.
http://store.mcetech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=CUBEDVDR8DL-A...roduct_Count=7
Check out the IMPORTANT NOTE...
$179 if you're replacing a CD-RW drive,
but $229 if you're replace a CD-ROM drive...
uhhh... WHY?
Anyone got any ideas?
TIM
I just looked on xlr8yourmac.com and out of 14 entries in their drive database for the cube all of them were ext firewire.
Also based on the instructions for replacing the drive in the cube on the apple site, it looks like an odd sized unit.
Okay, I decided to call them.
I was able to squeeze out of them that difference was for brackets and cabling.
That's some expensive brackets and cabling.
TIM -
I'm ready to just replace my cube. It's showing its age far too often these days.
noise or artifact/cube removal?
By darkdream787 in forum RestorationReplies: 11Last Post: 16th Jan 2012, 21:41 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Yet Another What Burner Should I Buy . . . but for MAC-External
By Doctor X in forum DVD & Blu-ray WritersReplies: 11Last Post: 17th Apr 2010, 04:08 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13 -
darm! my mac doesn't have DVD burner!
By yunakokimama in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2007, 21:07
