  1. Hello all,
    I have decided to experiment with adding background audio on my DVD's that I author in DVDlab. I use TFM to create seperate VIDEO & AC3 audio files. I was thinking about using the credit music from my film as the background audio. Anyone know what a good program would be to use (thinking about goldwave) and how I would do it, maybe adding fade in as well. If anyone has any idea how to do this it would be much appreciated
    Cheers Jim
    Apr 2003
    my computer, where else?
    just clip your audio down to the music/song you want for your background audio. transcode the clip to ac3 with ffmpeg, if needed. import the ac3 clip into the assets bin. click on the menu you want to use it with, then drag the ac3 clip onto the menu preview and drop it.
    I said I'll be done in a minute. I meant a Microsoft minute.
