I tried a couple of things and it works out well... like Sharpen edge, Quantize 35 35 or something... noise reduction.... btw... Iknow noise reduction works well but it takes a long long time to encode it... any other ways or best settings. Should I put it to MPEG Standard or CGI animation ??
I use MPEG Standard. CGI is for computer-generated animation like Toy Story. Also, for the most part leave noise reduction at it's default setting since increasing them will only blur the picture to where you can loose fine details. ALso try checking the Soften Block Noise to reduc macrobocks even further.
Using TMPGenc for DVD to DivX with consistency.
By meneedit in forum Video ConversionReplies: 8Last Post: 26th Jan 2012, 08:15 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
I have a problem with TMPGEnc 3.0 with DivX...
By blasedeviant in forum Video ConversionReplies: 2Last Post: 1st Feb 2008, 23:10 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
