I did see the Sticky thread about how to convert anything to any format using Mplayer. I have a couple of RM audio file that I need to
convert ----->MP3. Any recommendation of other software beside Mplayer??
thanks in advance.
simplest method is to play them , and record to a tape deck using high quality tape , the record them back .
This also helps keep the number of applications under control that are installed over time , making it easy to locate problems when things start playing up ... -
Google for RA2WAV, that should do it. Then you just need to convert to mp3.
With a name like Real7ime Converter though presumably it converts in realtime only. mplayer is much faster than realtime. Should also be possible to pipe from mplayer to lame.
Converting Flac to MP3
By Alexstarfire in forum AudioReplies: 7Last Post: 28th Jun 2010, 11:59 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
Converting DVD to MP3---HELP!!!
By sopps in forum ffmpegX general discussionReplies: 6Last Post: 5th Feb 2009, 13:01 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 21:25 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
