I have a vob file that I had converted using Xilisoft Video Converter. Now I have one huge 3.3G vob file that I need divided into smaller chunks. So I found this guide.
https://www.videohelp.com/forum/viewtopic.php?t=251085
I had used vobedit to create two seperate files.
VTS_01_1.80.ac3
VTS_01_1.m2v
Then I used IfoEdit0971 to author them, just like in the guide. And just like another user had, as soon as I entered in all the info(i didn't need chapters, I don't care about that), and I hit ok, i get "IfoEdit has encountered an error and needs to close." I don't think you need the specific technical error details, so I'll spare you. What have I done wrong?
Or is this good enough to put into the video and audio folders?
ifoedit is glitchy, especially on NTSC material (unless that was fixed recently).
Why don't you try DVDAuthorGUI instead (its free too).
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 15:19 -
How do I merge and compress VOB files?
By Mickie in forum Video ConversionReplies: 12Last Post: 23rd Jul 2011, 23:30 -
Corrupted WMV Files - Header is missing critical data
By Avide in forum Video ConversionReplies: 4Last Post: 6th Jul 2011, 04:01 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB Merge?
By chronic777 in forum EditingReplies: 3Last Post: 11th Aug 2008, 02:47
