As it was suggested to me to look at the conversion guides to
convert dvd to a format that was editable by moviemaker.
I seen guides from every format to dvd but none from dvd to avi or mpeg1.
What program may I use to convert a vob file to avi or mpeg1 format to edit in moviemaker.
TJ
VirtualDub VOB will import VOBs and allow export to avi - the codec is up to you. The Panasonic DV codec is great for editing but it's 13Gb/hr of footage.
Your choice.......
p.s. make sure the VOB is one large file otherwise you will get green frames at the ends of each VOB file.Regards,
Rob -
Rip to one big VOB using DVDDecrypter or smartripper. Virtualdub-mpeg2 or virtualdubmod can then open the VOB file. Convert to DV-AVI. Open this AVI in Windows Movie Maker.
More info here:
https://www.videohelp.com/forum/viewtopic.php?p=1353035#1353035
If you plan to put this back to DVD, output from WMM as DV-AVI instead of WMV, then convert that to DVD-compliant MPEG-2.If in doubt, Google it. -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 07:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 07:04 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 19:42 -
mpeg1 to mpeg2 conversion picture quality will improve or the same?
By live4fun in forum Video ConversionReplies: 9Last Post: 9th Jul 2007, 09:27
