I noticed that DVD Shrink has a feature that allows region encoding when re-encoding or re-authoring original, dual layer DVD movie discs. Would you recommend me to re-encode my backups as Region 2 discs? And if yes, what would I need to enter into the ProviderID text box?
I'm just wondering if this method is more reliable than burning region-free DVDs.
This is because my region-free DVDs can be read in my PC's DVD-ROM drive and my 2 stand alone DVD players (Yakumo XL2 and Alba DVD54) but can't always be recognised by my Playstation 2 console.
However, my region 2 DVDs are playing perfectly fine all the time. Especially in the Playstation 2 console.
So does anyone know anything further about DVD Shrink's region encoding capabilities?
Any help would be much appreciated.
Results 1 to 10 of 10
No, region encoding is just a software flag on the DVD structure to activate the DVD players on board protection. There is no increase in reliability. All players are designed to play region 0 DVD's, regardless if they are region locked or not. Region 0 or "region free" also means "world region" i.e that DVD is designed to playable world wide - quite a few commercial DVD's are made like this.
So what can I do then to get my DVD backups (which are region-free) to work flawlessly on my Playstation 2 console?
EDIT: My Playstation 2 is having real problems reading Region 0 DVDs. Including commercial Region 0 DVDs. -
Misread part of your post. Your playstation may be a different story. Have you tried different media?
Originally Posted by offlineIf in doubt, Google it.
Yep. I'm not a ps2 expert but you need either something like "DVD Region X" which I think is a special boot CD or a mod chip to play region 0 DVD's on your UK ps2.
Someone should know exactly; if not the try a search since this may be a common issue. -
No.
I assumed that Sony DVD-R discs would work fine on a Sony Playsation 2 console.
The thing is, I'm using the same blank discs for both DVD Video and for Playstation 2 DVD-ROM. And I haven't had any problems playing Playstation 2 game backups.
That's why I can't seem to understand why the same discs won't work as flawlessly for DVD Video on the same console. -
all I know is that it is possible
The Playstation is not really what I'd call a DVD player, regardless. -
And even the ones that are recognised by the Playstation2 console, they don't always play whenever I want them to. Some DVD video backups aren't recognised at all.
Does this sound like I need DVD Region X?
Toshiba HD-A2 and Region Encoding
By jspacemunkey in forum DVD & Blu-ray PlayersReplies: 10Last Post: 1st Apr 2009, 12:57 -
Strange region problem with DVD Shrink re-author
By Jetter68 in forum DVD RippingReplies: 7Last Post: 30th Aug 2008, 14:14 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 10:23 -
false dvd region mismatch with Dvd Shrink
By DB83 in forum DVD RippingReplies: 3Last Post: 27th May 2008, 13:09 -
Can't remove region restriction using DVD Shrink. Work-arounds?
By csloane@nwnexus.com in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 16:04
