Can someone help? I've just ripped a DVD with SmartRipper (.vob file). My problem is, when I try to convert with DVD2AVI, only the .d2v file is created, not the .wav. Is there a way to turn on/off the creation of the .wav?
Did you check for audio which track has been selected?
Just open DVD2AVI, select audio. Check if a track has been marked, and if yes, which track.
For English, mostly track 1 is used. ( you can check this in Smartripper. Open Smartripper, click on "stream processing" and check which audio file comes first, which second, etc. etc. The tracks in DVD2AVI will have the same sequence.
I hope this works,
The Dutchman -
Thank you! You were right - instead of being track 1 it should have been track 2.
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 19:35 -
Problems with VirtualDubMod .wav files
By 557953 in forum EditingReplies: 7Last Post: 6th Feb 2008, 13:51 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 04:23
