I installed Cuttermaran to do some simple video editing, but I can't figure out how to open files with it. I DVDdecrypted a movie and it's now saved as a Nero Showtime Movie. Cuttermaran is looking for mpv, m1v, and m2v files. Can I convert the Nero files? Thanks!
Results 1 to 12 of 12
What format did you output from Decrypter ?
I believe cuttermaran requires elementary streams. You either needed to output demux audio and video streams from DVD Decrypter, or you will now have to demux what you have. I would suggest deleting what's there now and demuxing using decrypter.
To do this, select IFO mode, then the Stream Processing tab. You will have to set both audio and video to demux by clicking on each stream that you want.
This will give you a .m2v and an audio file (could be .ac3, could be .mpa, depends on the audio on the disk). Cuttermaran should be able to work with this.Read my blog here.
Thanks, Gunslinger. I'll try that.
Also, I downloaded a couple things when working on this problem. Are these of any use to me for basic editing, or should just I delete them?
http://www.xpcodecpack.com/
and
https://www.videohelp.com/tools?tool=AVIcodec -
No codec packs.
You can also use Gspot to identify what codec you need or what you have. Gives a little more info than AVIcodec.
The problem with codec packs are you get the codecs you might need and a whole bunch more you don't want. They can conflict and mess up your whole system. Use Gspot or AVIcodec to identify, then download only the ones you need for the file. Save yourself a lot of grief.
Lol, I went ahead and deleted the codec pack.
I tried to demux with DVDDecrypter, and successfully got the video portion (which I opened with Cuttermaran), but no sound files were created. Both audio and video boxes were checked when I decrypted. Do I need some codecs or something? -
You have tick both streams, but you also have to click on each stream individually and then click the Demux radio button. This is a trap for young players because you assume that by ticking both streams, and select demux once, you get both - you don't.
Read my blog here.
Ok, I got the demux to work. However, the video is split into 4 files and the audio is one big file. Can I make the video all one file? Cuttermaran will only let me open one at a time.
Cuttermaran 1.70 synch issue
By cjbrown80 in forum EditingReplies: 5Last Post: 30th Aug 2011, 12:16 -
Cuttermaran doesn't execute
By Somebody2 in forum EditingReplies: 0Last Post: 7th Oct 2010, 16:23 -
Cuttermaran Encoding Problem
By SkyIs2Blue in forum EditingReplies: 4Last Post: 9th Jun 2010, 16:15 -
Cuttermaran JTI error
By tonyp2 in forum EditingReplies: 0Last Post: 16th Sep 2009, 11:28 -
Cuttermaran with Vista?
By Rychezilla in forum EditingReplies: 7Last Post: 18th Apr 2008, 18:16
