I have reposted this with a new header thinking that the old header may have been confusing.
I am attempting to burn a Video TS folder that I ripped with MTR. The folder is approx 7 - 8 gig in size. Once I start the process it appears to compress fine then begins burning. Everytime in the last few minutes the Toast software locks up. Any thoughts on how to stop this. I selected buffer underrun prevention in the setup but it did not help. I have about 10 gig of HDD left. Could this be the problem? Any help will be appreciated.
Yes only have that amount of space left on the HD could be the problem. Try to clear out at least 15gb so you have about twice the size of the file.
I cleared off 30 gig of HDD space and attempted again. It still hangs up. Once it is locked up it will allow me to click the abort button and then states that it is aborting but never aborts. Only a force quit stops it.
What burner are you using? I have had problems with my Pioneer 109 with Toast 7. Sometimes it locks-up during burning DVD's. I have tried different media (Fiji, Sony, Taiyo Yuden, & Ritek) with the same results. Sometimes they work and other times it locks up. So I have been using my NEC 3520 for burning and the Pioneer for ripping. The NEC & Toast 7 have not had any problems.
Sony S580 region locking
By cheekiestgrin in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2011, 20:46 -
Help; Capture Locking Up with Canon Elura 90 DV
By bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 23:37 -
Slow & locking up
By BLSAMPLES in forum ComputerReplies: 7Last Post: 17th May 2010, 15:17 -
Why is DVD Decrypter locking up?
By dphirschler in forum DVD RippingReplies: 11Last Post: 14th Jan 2010, 22:34 -
Subrip2scc locking up?
By Lbrow in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 15:08
