I have DIvx movie in AVI format with so quiet audio.
What is the fastest way to gain the volume??
Results 1 to 9 of 9
Do you want to just change it for playback, or permenantly ?
Virtualdub can change the gain of the audio stream.Read my blog here.
fastest would be to turn up the volume knob
I mean pernamently.Probably separate audio from video,gain the volume for audio and join video back with audio
Mine goes up to 11!Originally Posted by BJ_M
Okay, seriously, the "fastest" way to do this would be as already noted -- demux, run the audio through something like Goldwave, "normalize" to what sounds loud enough to your ear, then put it all back together again. But do you want to keep it in DivX format? If so, I'm not sure if pulling it apart and putting it back together is all that straightforward, but who knows, probably is. I'm sure a lot depends on what hardware/software you have to work with; do you already have the necessary tools or are you asking for what tools would work best? -
I'm having a very similar problem, but the file is an .mpg, MPEG-2 stream, VirtualDub tells me, so it won't run the file. Is there anything similar to VirtualDub I can use for this mpeg file?
Yup, try VirtualDubMod, it's freeware and it'll open mpeg2 files.Originally Posted by raubt
Hi-
Well, what kind of audio is it? If you don't know, open the AVI in GSpot to find out.
If AC3, then go into the AC3 Filter configuration and turn the Preset to Loud, or fiddle with the sliders. If MP3, then demux and boost the gain with MP3Gain. Be careful of clipping (distortion). Then remux.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
