  1. Member ex5125's Avatar
    Nov 2005
    Is there a problem with the forum search facility?
    I tried doing a search in the SVCD2DVD forum for the word "version" but it returned no results yet when looking through the posting list I can see that there is a posting with the word "version" in it:
    https://www.videohelp.com/forum/viewtopic.php?t=283432
    Any ideas?
    It should work now, at least if you limit the search to one forum section...or else will you get too many hits.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    On a side note, you'll find a link for doing the same search on google on the search results page. You'll get better results from that.
  4. Banned
    Feb 2005
    USA
    When the word you're looking for isn't returned try another similiar word or word groupings until you achieve the results. If all else fails, you can always start a new thread asking for info. You will then be treated to those who tell you to use the search function but you will also find helpful members who will point you in the right direction.
  5. Member ex5125's Avatar
    Nov 2005
    Thanks Baldrick - its working fine now!
