When asking TMPGEnc Author 1.6 to load a mpeg file it gives the following error message- "Could not initalize decoder". What does this mean and what do I do to "initalize" it, if possible.
The files source is valid as I can load it into MyDVDit and it will play as a mpeg file in Windows Media Player.
TMPGEnc seems to have a problem with this one mpeg file as it works with other mpeg files I have created in Studio 9 using their Movie Box Deluxe USB 2.0. It is a captured commercial VHS tape (dare I say that here?) that I want to archive on DVD.
You think the file is valid but the only time I've seen that error is a bad file. You can't initialize the decoder as it is internal.
Try the trial version of VideoReDo and run the quickstreamfix under tools on that file and see if it helps.
Good Luck
By the way, playing in media player is not a test as it'll play many defective files Ok. DVD authoring is much stricter to prevent authoring coasters. -
I get that same message randomly when I'm burning off my dvds on my Sony recorder. They all occur when it's burned on the dvd video format. Then I reburn it in the VR format and it will load up. This just happens ramdomly on the dvd video format, on the DVD-VR burns they all load up 100% of the time.
TBoneit,
I did as you suggested and the repaired file worked in TMPGEnc Author like a charm. Thanks a million. BTW, the reply I got from tech support at TMPGEnc wasn't anywhere near as helpful and wouldn't have solved the problem. So thanks again! -
If in doubt, Google it.
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 08:57 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
DVR 633 fails to initalize when burning to DVD
By Howardlan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Nov 2007, 18:46 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 12:27
