  1. Hi,
    I want to backup a dvd9 to 2 dvd 5 but I can't split it with VobBlanker because it has multiangle and VobBlanker don't support multiangle.
    Which software can I use to split it in 2 dvd-r while keeping all the menus working.
  2. dvdremake pro is your only option I think. even using that may not work.
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    if you want something free instead I think DVDStripper worked with multangles as I did The Matrix with it. I'm not 100% sure if it works with every DVD as I think Ifoedit had angle problems with version 0.95 but it's been such a long time now since I used it
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    IFOEdit can do it also ..... oh wait, DVDStripper is a GUI for IFOEdit, isn't it ?
    If in doubt, Google it.
  5. I splitted my dvd with ifo edit.
    The first disk works fine but I have a small problem with disc 2. It plays fine but the chaperts are not correct.
    The original dvd has 20 chapters.
    I cut at chapter 11, so the 2nd dvd contains chapters 11-20. When I select the charper 11 in the menu of dvd2 it doesn't start at the beginnign of the video but at the position of the beginning of chapter 2.
    Chapter 11 must start at position 0 in the video and not at the chaper 1 length.
    So is there a way to change the chapters time ? Ifo edit won't let me change chapters time or remove chapters 1-10.
    With PGC edit I can change the chapter affected to a menu button but not the chapter length or chapter starting point.
